Cant figure out the 00302 ABS Fault Code??
  • Cant figure out the 00302 ABS Fault Code??
    Hi everyone. I am struggling with a issue I can't really figure out. I recently had to change the windshield washer pump and in doing so I stupidly disconnected the ABS pump while the battery was still connected. And in doing so it seems the car freaked out and gave me a fault code.
    I get the 00302 fault code which after reading off Vag-Com it seems like the J106 relay solenoid valve is supposed to be the issue. But I can't access the relay without removing the entire ABS pump.
    Is there anything else that can lead to the same fault code? Because it seems very unlikely that the relay decided to stop working the second I disconnected the ABS pump.
    Thanks in advance for the help!
    What is the car?
      A 1995 urs6
        You mean a type 4A2 8?? Ur...
        The Bosch 5.0 I assume.
        00302 Solenoid valve relay -ABS -J106
        - Defective wiring or excessive contact resistance in earth connection to solenoid valve relay -J106.
        - Open circuit or short to positive/earth in wiring between relay -J106 and control unit -J104.
        - Solenoid valve relay -J106 or hydraulic unit -N55 defective.
        I don't have a wiring diagram.
