With the dollar in such abysmal shape, you geezers need to quit fiddling with kluged Porsche/A8 bits and get a properly engineered braking system on your sleds. May I suggest the Stoptech 332mm kit? Provided are:
*two (2) 4-piston, aluminum (improved brembo design) calipers w/mounts
*front and rear stainless lines
*two (2) 332mm front rotors with aluminum mounting hats
*unsprung weight savings is 7 lb under the OEM G60 setup
*braking performance is more than you'll ever need
*17" road wheels are required
*calipers may not clear all 17" wheels but 5mm MAX spacers should suffice.
*Shipping to UK is about US$150
Please contact ben@quattrospeed.com if you are interested
You can visit http://www.stoptech.com for technical details
