I decided to install my 996 (actually Boxster S) BBK this weekend on my NA UrS6.
I was planning on cutting the pins down by 1mm each to accept the 314x30mm rotor. But I just realized that my father has my dremel.
What is the method for pushing the pins in? Do I just use a big *** "C" clamp and a block of wood?
It looks like there are some type of locking pins that hold the caliper pins in though.
TIA
Dave
PS - Saw a post where someone mentioned that the Boxster S version was designed for 32mm thick rotors. Can anyone confirm? The rotors fit but with probably .5mm clearance rotor to pin.
TIA
Dave
