A mate of mine has a set of brembo calipers off of a fiat coupe turbo he said i can have them cheap does any1 no if u can fit these 2 a s2?
Fiat coupe turbo brakes
Tags: None
Fiat/alfa/lancia/peugeot coupe caliper is lug mount style. This means trouble fitting to the S2. Also it will be quite PITA due to the offset. So forget it unless you have access to the machine shop. If not, I don't think they are worth it.
Sau200 20vt 88' 3b, human carrier
