Ummmm ????? Grinding noise????
  • Azman
    • Sep 2005
    • 3205
    Hi guys.
    SOrted the caliper bolt out as per previous thread. Now after having the car 4wheel aligned today after a spirited drive I am getting a rubbing noise and vibration through teh pedals only when warm????
    Any clues or ideas. Everything looks fine the only thing I can think of is the pads binding slightly but they should be okay as all in new in that area.
    Def coming fromt eh front though. Only happens at slow speed in a straight line, not when turning the wheel to the left or right.
    On the plus side the car feels alot more planted after the Wizard worked his majic today on the alignemt (and unstuck one of the track rods!!!)
    So any thougths on this noise!!! Only started today.....
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • Acidburn
    • 13459
    Have a quick look under and see if you can see anything that might rub etc.
    I know its not likely but when you lost the calliper bolt could it have damaged the pads/discs in any way?
    • Azman
      • Sep 2005
      • 3205
      Not that I can think of I may just have to give it a few good stops to adjust the pads from the caliper movement possibly!!!
      Dark Grey Avant
      RS2 FARB
      • Azman
        • Sep 2005
        • 3205
        Thats a no then been for a good drive today and a spirited one to which would have got the pads to a flat surface. Couple of emergecy stops thrown in there for good measure from 70 - 10mph. as soon as the padal is released hey presto there is the noise again. As is the calipers aren't retracting enough. Thinking I may have some air in the system it seem only to be happening on both front calipers now so would the air be a fair assumption????
        Brakes are hard on the pedal with very little squeeze and bite head into steeringwheel hard so can't really figure this one out????
        Dark Grey Avant
        RS2 FARB
        • archiboy24
          • Sep 2003
          • 286
          Can you feel a high frequency vibration in the steering wheel? Goes away when brakes are applied or by turning the wheel slightly to either side while driving? I have the same issue and I believe it's a common problem for those who have done a Porsche big brake upgrade. I don't recall exactly what causes it (or how to remedy it) but I think there are some threads on this. Not much help I know, but sometimes it's nice to know there are others who feel your pain!
          Ben
          Calgary, Alberta
          Canada
          1991 CQ e//S2 w/ RS2 spec 3B 20vt
          Panther Black Metallic
          www.moda-architecture.ca
          • Azman
            • Sep 2005
            • 3205
            Ar with alot of noise too!!!! Does go when the pedal is pressed and only comes when the brake are at operating temp (i.e. on a run )
            Dark Grey Avant
            RS2 FARB
            • pixsaudisex2
              • Sep 2004
              • 3110
              groves on the rears of the discs catching the pads ... or front...
              • Azman
                • Sep 2005
                • 3205
                Wouldn't have thought so as they are brand new and done less than 1K miles..... will try a system bleed tomorow and see if that helps.
                Dark Grey Avant
                RS2 FARB
                • MattS2
                  • Apr 2006
                  • 657
                  Have you tried everything mentioned in this thread?
                  Hope it helps.
                  Matt.
                  Ex owner of a 1993 Silver Avant - RS2 spec.
                  2002 A8 sport 2.8 quattro Sold
                  2003 A6 Avant Tdi
                  Mk Indy 2.0 pinto circa 160 Bhp
                  2004 VW Caddy SDi
                  2002 Civic Type R
