Are these right for the A8 disk conversion?
    Are these the right porsche calipers for the A8 disk conversion?
  • mcandmar
    • Apr 2004
    • 5118
    I dont think so, they look like 964 or 993 calipers to me. Others will know for sure. Dont forget A8 disks are 5studs incase your wishing for a bolt on solution.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
      D'oh! so F&R hub conversion needed too.. ok, i'll forget that idea then
      • mcandmar
        • Apr 2004
        • 5118
        There is a few options, Corey did mention he has a bolt on solution for 4studs, he may be able to tell you more.
        I'm going for a very sexy two piece disk setup with 4x108 bells, isnt that right Corey
          I'm sure the options are there - what will be the cost of replacement rotors on your exotic setup?
          • mcandmar
            • Apr 2004
            • 5118
            no comment.
            • Smith_S2
              • Feb 2007
              • 634
              mmm...... you can get them in black! You need to get 996 brakes off of an 911! speak to Bry he's you man for brakes. He does brake upgrade kits well worth a look!!!
