Cayenne Turbo Callipers and Fitting on an S2?
  • Dubbedup
    • Jan 2006
    • 291
    I have just bought a set of Cayenne Turbo Calipers, and was wondering does anyone provide a fitting kit, carrier etc, and what size of disk to use as well please..
    Any help much appriciated.
    Thanks
    Stevie
  • Dubbedup
    • Jan 2006
    • 291
    Oh yeah, and to get them mounted towards the front of the car, rather than the standard S2 position, I take it I am going to have to change the struts?
    all guess work just now till I get advice from you guys.
    Thanks in advnce folks.
    And be gentle, I have never done this on an S2 before...
    • Acidburn
      • 13459
      Yeah probably have to change the struts or get something made up but not 100% sure, have a look in the search functions as iirc I have seen this done before.
      If you don't mind me asking what did they set you back? you can pm me if you want. cheers, if I find the link i'll post it in here.
      • chrisarc
        • May 2004
        • 44
        cayenne calipers
        Tim Cooper at renntech in ellesmere port has fitted said calipers to an s2, ,,,HUGE ,,car had 19'rims ,
        think its renntech uk
          Speak to bry and corey you need new caliper mounting brackets
          • Dubbedup
            • Jan 2006
            • 291
            Cheers lads, thanks for the replies.
            Just incase there was a person that had done this already and they had the measurements for the caliper carriers and what discs are best to use.
            I will get in touch with the guys at Quattronics...
            Any advice in the mean time would be appriciated.
            Thanks
            Stevie
            • chrisarc
              • May 2004
              • 44
              cayenne calipers
              like i said Tim has done it , had the mounts made , worth a contact , if only to compare cost to the rest
              • S2_Dave
                • Aug 2005
                • 456
                Tim not at QRSport anymore then, or is this the same company but with a different name?
                David
                '91 3B S2 Coupe
                • Jas11n
                  • 5067
                  He left.
                  2001 Avus Silver B5 RS4.
                  1995 S2 Coupe - sold (sniff)
