How much torque and what loctite for bolts that holds the rotor center to the rotor?
  • NEO
    • Oct 2003
    • 326
    Does anyone have any clue about the torque that the bolts that holds my rotor center to my rotors should be tightened with? Anf also what loctite that might be suitable for the task?
    The centers are from Touareg and the discs from RS4-b7. So bascially standard stuffs.
    Maybe I have asked this here before in some thread or some of you guys... But if so. Please answer here to. =)
    A couple of pictures so we talk about the same thing...
    Center:
    Center (in my hand =)), rotor (on table) and bolts on the top right corner:
    /NEO - I have a sexual thing for big brakes.
    www.irry.com | Irry got a face lift!
    #nordicaudi @ irc.nordicaudi.com
  • ericd
    • Nov 2003
    • 1240
    When connecting bells(centres) to discs(rotors), the torque value I used was always quite low, something like 13-15Nm, I'm sure Bry or Corey will have more exact figures
    • NEO
      • Oct 2003
      • 326
      Hey Eric.
      Oh... That's low. Really thought it would be harder. But on the otherhand it's "lock nut's". Do you use any loctite? Do you reuse old bolts and nuts?
      • Corey
        Banned
        • Sep 2003
        • 2793
        10Nm tightened diagonally.
        Corey
        01636 822288
        • NEO
          • Oct 2003
          • 326
          Any loctite? Resue old bolts and nuts?
          • NEO
            • Oct 2003
            • 326
            So no words on loctite or reusing old bolts and nuts?
            • ericd
              • Nov 2003
              • 1240
              I didn't use new bolts/nuts on mine, though I did look around for a kit , readily available in sets of 24,16 from places like compbrake and a few others , never used any loctite either
              HTH
