Really nasty dirty brake porn
  • curlyks2
    • 1069
    Better pictures of those well bedded in discs. Look away now if you're of a sensitive brake disposition...
    Ck.
    Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
    • curlyks2
      • 1069
      • curlyks2
        • 1069
        • Skull
          • 3506
          • Country: Slovenia
          Audi Quattro WR
          • S2_Dave
            • Aug 2005
            • 456
            Originally posted by philS2
            quick question.if drilled discs are no good,how come porsche and mercedes to name a few fit them as standard to their high peformance cars?
            They're "perforated". The holes are cast rather than drilled, meant to reduce the potential for cracking.
            David
            '91 3B S2 Coupe
            • denniselbows
              • 740
              looks like all the disc wear is one sided is your caliper on central?
              never set your expectations to high that way you are never disapointed
              • Fat Audi 80
                • 10547
                Look like should left those a little late!
                The Perfectionist
                • curlyks2
                  • 1069
                  Yup the calipers are on central. It's the inside faces that are super-worn. The other disc (used as a stand in the pictures) isn't quite so shagged, but it's still somewhat less than even.
                  Ck.
                  • curlyks2
                    • 1069
                    Yeah it was a slightly nervous drive back from the garage where the original pictures (first post in this thread) were taken.
                    Ck.
                    • Fat Audi 80
                      • 10547
                      Are the insides of your wheels full of iron filings as well. I will look forward to trying to get those off...
                      The Perfectionist
                      • s2driveruk
                        • 12696
                        holy sh*t thats amazing. Never seen anything like that before Definately very strange wear to be so much on the inner face only, are the pistons all moving freely?
                        1992 3b S2 Coupe
                        • volcano rs
                          • Jun 2005
                          • 2265
                          Originally posted by Jamo
                          Said it before and I'll say it again, cross drilled discs are all show, Grooved are all good, x drilled no thanks!
                          I'll be replacing the x drilled on my car when I have some cash ( LOL ) to upgrade the front brakes.
                          if thats the case why do the best and fastest porsches have them ?
                          • s2driveruk
                            • 12696
                            I have to say i have not ever been convinced that they dont work. In conjunction with directional vanes in the disc, they should work really well to provide some additional cooling.
                            If the performance drop was so bad using a cross drilled/cast disc then the likes of Brembo and Porsche etc wouldn't use them IMO especially not on a high performance car. I think the option of a wide diameter disc, the vanes and the additional cooling through the cast holes/cross drilling means you can reduce the weight on each corner as you can increase performance from a smaller diameter disc.
                            1992 3b S2 Coupe
                            • curlyks2
                              • 1069
                              Nope, it's just standard muck and dust inside the wheels I think, although there is quite a lot of it
                              Yup. They weren't binding at all.
                              Originally posted by newsh
                              The Textars with plain discs were well wooden feeling.. I'd never do that again.
                              Glad it's not just me: tried textar pads, hated them, never again.
                              Ck.
                              • Flat on my back
                                • Jan 2007
                                • 2449
                                The same on both disks?
                                Most wear on the inside edge...means the inside pistons have been doing all the work, or the sliders are seized
                                Keep a very close eye on disk wear...
                                Carlos.
