Hi,
Anyone know if you could hook up the S2 handbrake to an STI spec brembo rear 2 pot caliper?
I know i will need some custom brakets etc but i'm more concerned about the ability ti get the handbrake to work with the brake shoes in the piston which work as the handbrake.
I'd like to install better rears and a brake bias valve that i can play with ideally
David
David
