Possible hydraulic servo problem?
  • Key Walshe
    • Feb 2007
    • 422
    Seems there's a new problem with my Power Steering system which is now affecting my brakes! As most will know the PS and Brake warning lights run off the same system, and as I've got a knackered PS pump when the said warning light (!) (looks like that) came on I presumed it was the same seal in the pump gone!
    To my surprise the PS reservoir was dribbling its fluid out of the top which initially indicated too much fluid in there, although I knew there wasn't! After having a look round that, checking the seals on the pump (all ok for now) and then the brake system for any problems we were a little stumped ('we' being myself and StepDad who has his own car repairs business!) as everything seemed ok to look at! The car drove ok for around 10miles, no brake problems or steering issues, then in slow moving traffic the brakes wet very juddery with alot of resistance in the pedal and even less stopping power compared to usual
    Then, that night checking the manual it came to light that the 2 systems (PS & brakes) were more linked than first thought due to the Hydraulic Servo or Central Pressure Reservoir (after searching on here, is it aka the 'Bomb'? Quite apt considering!). Can anyone confirm that these symptoms are the bomb and if so, any reccomendations on how to replace it, ie who to go to as I believe they're around £220from VAG, and I've also read they can possibly be reconditioned, any truth in that and again if so, any reccomendations (I've read 7 Stars in a previous thread)? And the usual question, is it the same as any other Audi models, I'd guess the 20v is the same but any others?
    Sorry for the long winded thread, but my greatest appreciation to anyone who can help out - damn frustrating having this car at times, but so enjoyable when all's well!
    Audi 80 S2 Nothelle N300 Avant, 1993, Amethyst Pearl VW/Audi Car Magazine article about this very car
    Audi A6 Avant 2.5 TDi, 1995, Arctic Silver (now sold)
    BMW E36 325i Coupe, 1993, Diamond Black (now sold)
    VW Polo 1.0L 6N, 1998, Red (the missus' car)
    Aprilia Rs250 motorbike, 1998, Black (the weekend toy)
  • Cullam3n
    • Aug 2007
    • 993
    If the brakes are not being assisted, than either the bomb or servo is at fault. To diagnose it as the bomb, after a good run shut off the car and count how many times you can push the brake pedal before it gets hard. If it's a single digit number then your bomb is knackered.
    The bomb is rather expensive from vagparts but you can get them from Paul in Luxembourg for 130euros (before tax + post) for brand new ones. I have one fitted in mine, top chap.
    If your pedal is juddery as in you slam on it and it kind of pulsates as it goes down your servo is knackered (I just retcified this issue on mine)
    HTH
    • Key Walshe
      • Feb 2007
      • 422
      Thanks very much for the reply, very helpful! Going off the description of the symptoms then it's both lol and thanks for the namedrop, I'll get in touch with Paul once I've had a chance to look at the problem abit more thoroughly
      Gonna be a lean, lean, lean in the Walshe household this Christmas lol
      • Cullam3n
        • Aug 2007
        • 993
        To be fair, if your servo is knackered, you pedal will be hard no matter what as it's not building up pressure. I put a brand new bomb in mine before I replaced the servo and it didn't really make too much of a difference.
        I think Paul's site is www.custom-auto-craft.com he's an avid audi nutter as well
          Follow the technical area into Running Gear on http://s2central.net for some hydraulic info.
          This smells to me of bomb or servo failure - theres some valves inside the bomb which can fail. I need to add some other bomb/servo test information - seems like its not all there, but you need a high pressure guage to verify that 140bar is where it should be !
            My money is on the Servo - I've just had to replace mine, on the CQ which was doing almost exactly the same as yours, but worse - I couldn't stop at all!!
            I'm guessing your servo is on the way out, but not totally fooked yet.
            Doubt its anything to do with the bomb unless its some kind of valve failure like Paul suggested - the brakes work fine on my 20v with a totally dead bomb (pedal hard within 2 pumps).
            Swap the servo first i'd say
            I got one if you need it, came off a CQ with about 110k on it
              Ahhh - just found it - there IS a quick servo test on s2central.net in the hydraulic section. That should nail it - though I find access is bl@@dy terrible in that area !
              • Cullam3n
                • Aug 2007
                • 993
                I still have my bad servo that I want to disassemble to see exactly what went wrong, because I did the servo test and it didn't drip anything.
                  AFAIK you can rebuild some of them, not others. Ask Chris (LHD Kid) he was doing this
                  • Cullam3n
                    • Aug 2007
                    • 993
                    Was reading somewhere that they are not meant to be rebuilt... not sure if the servo on the v6 is different.
                    • Pirvu Eugen
                      • Apr 2007
                      • 1978
                      • Country: Romania
                      only the old URQuattro servo unit can be rebuild. http://www.quattro.ca/Urq/Brake_servo_guide.pdf
                      The new models can not be rebuild. I will make some pictures from the both units internals to see the diferences between the old and new models.
                      The idea off Audi is to buy a 600 Euro unit in place of repair the old one with 10 Euro.
                      Good guys, not?
                      Hope this helps!
                      Eugen
                      • LHD_Kid
                        • May 2006
                        • 3696
                        Good guys, not?
                        Hope this helps!
                        Eugen
                        Yes, this is correct..... Eugen kindly dismantled a few different models of servo from his 'stock' to see if there was any way of replacing any internal seals, and only the very early ones are servicable, unfortunately...
                        This means, as said, you spend 360 quid instead of a fiver....
                        Chris
                        • Key Walshe
                          • Feb 2007
                          • 422
                          Thanks for all the replys and advice, s2central especially thanks for the link to your site - some great info on there, not just on this subject but loads others too! But, when you say there's a test in the Hydraulics section I couldn't seem to find that section, unless it was THIS section of the brakes bit, brakes_06!
                          And LHD_Kid, when you say it was only the very early ones that are servicable, I guess you mean even earlier than a '93 S2 Avant?
                          • LHD_Kid
                            • May 2006
                            • 3696
                            Fraid so mate.... turns out, it is even earlier than a 1991 3B too...
                            Sorry
                            Chris
