Bah, my new front brake setup has now developed a London taxi-esque habit of squeaking/squealing.
There are two different pitches of squeal, one that happens when light brake pressure is applied which is a low-ish pitch, but goes away when you stick more force on, only to be replaced by a very high pitched taxi squeal under harder braking effort. It's annoying as hell!
What causes this and how do I cure it? It's embarassing!
Also, I'm getting an occassional resonance after repeated brake effort, as if the pads don't disengage from the discs fully? Is this normal with Porsche calipers? Anything I can do about that?
Brake force is great though, a real worthwhile upgrade.
