I have seen pictures of porsche brakes under those wheels, iirc will hollman from PPC (practical performance magazine) has them on his ur quattro under standard rims.
Compomotive do a replica S1 wheel(16x9) so you should be able to fit 330mm discs no problems.I'm fitting 280mm discs with Porsche Boxter calipers on the rear no problems under a 15" compomotive MO but will be going for the 16x9 S1 replicas so I can fit bigger on the front.
thank u!!
can you give a link where to buy s1 replica wheels?
I am using 280mm discs from a Corrado modified for the Audi hole pattern and some s2 calipers at the front and 256mm Mk3 golf TDi (front) solid discs at the rear with relocated standard calipers. Amazing difference for very little outlay compared to brembo set up. Depending on year you may need the front struts from an early series 3 that come with the wider spaced monts for the S2 calipers. This does away for the need for spacers that I prefer not to use.
1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
2004 A4 2.5TDi convertible, re-mapped to 180bhp
2011 A5 sportback 3TDi-Backbox delete, remap
Not yet he doesn't as he can't make his mind up as to what bloody wheels he wants to use and the pictures are of conversions we have done btw.
Originally posted by MikeS2
Sport quattro disc of 295x28mm will fit inside a standard wheel
but needs machining to ensure the wheel has the correct offset.
