RS2 rear brakes on Coupe
  • Stick Insect
    • Dec 2003
    • 2338
    Originally posted by The Spanish
    Calipers can be bought throw Porsche but remember the 993 twin turbo has the calipers placed towards the front of the car and the RS2 has them placed towards the back of the vehicle. So you have to mount them upside down them. Just remember the left must stay on the left of the car and the right on the right. Many experts here can tell you how to do this correctly but is very simple.
    Rafael
    Corey pointed out that the cross over pipe should be swapped from one caliper to the other when moving the bleed nipples. HTH
    David
    • Jeffer
      • 2057
      Foock me!
      What is the difference with the 304 mm disk. Is that only the diameter? Is that hat the same as the 322 mm hat?
      I ask this because i have a set of 304 mm lying around so that i can compare those with the 322 mm porsche disks. so that i'm 100% certain wich disks to have.
      greets and thanks!
      RS2 Black - stock 315 HP
      RS2 RS blau - stock 315 HP
      Sport Quattro - 1005 HP
      High Octane website
      • The Spanish
        • Nov 2003
        • 719
        #33
        Jeffer,
        304mm disc is a 1-piece design and the 322mm is a 2-piece design, so you can not separete the hat from the 304mm disc
        If you use the 993 turbo disc you ordered, you will find when you fit that the disc is not centered with the caliper.
        Solutions if you cannot give back the discs you ordered from Porsche:
        1. Keep the disc, buy others from Audi and swap the hats when they are worn out in the future (what I am doing)
        2. Sell the 993 twin turbo discs
        3. Have custom caliper carriers made to correct the offset difference, I am sure that because of the price difference of the dics from Audi and Porsche you have the cost of the custom job payed in two sets
        4.
        Rafael
        94' RS2 Coupe TT (Twin Torsen )
        • Jeffer
          • 2057
          Okee now i see. Well the disks are ordered but not pickup yet. So I probably can trade them for other disks. But Ten I need to know the part nr. from the right disk from porsche for the 322 rs2. Can you help me with that?
          cheers
          High Octane website
          • The Spanish
            • Nov 2003
            • 719
            #35
            Sorry to keep the bad news.
            But I think Porsche doesn't have any part number for 322x32mm discs with Audi RS2 offset. They were specially produced for Audi, both front and rear.
            On the other hand the 304mm ones are from a Porsche 928.
            Maybe someone can correct me
            Rafael
            • Audi_CQ
              • 940
              • Country: Norway
              #36
              Rafael
              Porsche 911 3.6Turbo has the correct discs. They are one piece with right offset and drilled , but more expensive then the 2-piece 993tt discs.
              Cheers,
              Roger
              • Jeffer
                • 2057
                I've compared the 304 mm disk with the 993TT disk. There's 5 mm offset difference in it.
                Is the original rs2 disk also 2 piece or one piece?
                I think I going to order the rs2 disk. Its like 220 euro's a piece or something.
                High Octane website
                • Jeffer
                  • 2057
                  Cheers,
                  Roger
                  Are you 100% sure? Are you using those same disks?
                  High Octane website
                  • Jeffer
                    • 2057
                    The thing I don't really get is that TOTS uses the 993 TT disks on their cars?
                    High Octane website
                    • Audi_CQ
                      • 940
                      • Country: Norway
                      #40
                      I did the same "mistake" and bought 993tt discs. I called the dealer and asked if they had any discs with the right offset. They told me that 911 C2 turbo 3.6 was the right offset. 928 GTS also right offset, but not "drilled".
                      Cut from this site : http://www.944s2.com/brakes/brakes.htm :
                      (M030 option = RS2-brakes )
                      " ROTORS: Three factory front rotor options are available for big red or big black calipers:
                      928 GTS — 1-piece, "non-drilled," same offset as '87 and on 944 Turbo or 944 S2.
                      911 C2 3.6 Turbo — 1-piece, "drilled," same offset as '87 and on 944 Turbo or 944 S2.
                      993 Twin Turbo (TT) — 2-piece (separate rotor and mounting hat), "drilled," 5 mm less offset than above options. Not for use on cars originally equipped with S4 calipers (M030 option) unless custom alloy hats are used.
                      All of the above rotors have a diameter of 322 mm (12.68 in) and a thickness of 32 mm (1.26 in). The 928 GTS rotors are reasonably priced and work well on the street, but are not as "sexy looking" as the drilled rotor options. The 3.6 Turbo rotors are similar to the GTS rotors but have cast-in ventilation holes made by a special process, as do the 993TT rotors.
                      I originally chose the C2 3.6 Turbo rotors because I wanted the look and added cooling the "drilled" rotors provided but didn't want the extra expense of fitting the 993TT rotors and custom hats. I've now changed to the 993TT rotors and custom alloy hats. This saves a bit of unsprung weight, but my "calibrated arm" says it isn't anywhere close to the 4 lbs per side most vendors claim. "
                      Cheers,
                      Roger
                      • Jeffer
                        • 2057
                        In my quest for rear rs2 brakes on my coupe. I've salvaged a rs2 rear subframe with all the bits exept the calipers. If anyone wants to do the same conversion, then I have all the parts lying around for another rs2 rear brake conversion.
                        I've ordered also the "real" rs2 front disks. I'm getting nuts from all the disks. And the handbrake cables.
                        So I'm almost there
                        cheers
                        High Octane website
                        • Jeffer
                          • 2057
                          btw the rs2 disks were 20 euro's more expensive then the 993tt disks a piece.
                          cheers
                          High Octane website
                          • The Spanish
                            • Nov 2003
                            • 719
                            #43
                            Hi Jeffer,
                            Do you have measers on the S2 and RS2 rear drivesafts and outerjoints?
                            Or better still, Do you know if they can be swapped with the RS2 outerjoints?
                            Rafael
                            • Jeffer
                              • 2057
                              Oh **** sorry rafael, I totally forgot about that. This weekend i'll check it. I will check if the outer joint from the rs2 fits on the s2 driveshaft.
                              cheers
                              Hi Jeffer,
                              Rafael
                              High Octane website
                              • The Spanish
                                • Nov 2003
                                • 719
                                #45
                                Thanks a lot
                                cheers
