Looking at Dan's specifications - its a 314mm disc turned down to 304mm. ?
If so, you could use a 5mm spacer under the caliper and use the discs full size.
Does the pad sit on the disc without any overhang on the inside or outside?
How much clearance have you got from your caliper to the inside of the wheel?
You could get a pair of SEAT brackets machined which would eliminate the spacer / disc machining issue completely, if you have room within the wheel.
