back brake sticking - new caliper?
  • Nj
    • Jan 2007
    • 3420
    • Home: Scotland Current: Finland
    gents (and ladies if inspired)...
    My back right brake is sticking on the 16v. wheel was warm after a run the other day and i can feel it unstick and rub a little as I move off. Left it into the garage and the mechanic said it could need a new caliper when I was giving him the keys. Just want to be educated here. any thoughts on why the brake would be sticking and/or why it would mean a new caliper?
    cheers
    1990 CQ20v
    2001 3.0 B6 A4 Avant Quattro Sport
  • Acidburn
    • 13459
    Might be lucky and just need a good clean up/grease, thought the calliper on one of those should not be too bad tho.
    • jameswkr
      • 538
      Agreed. It could also be the handbrake not releasing properly..if you remove the wheel you can check for (correct) free play (or not) on the lever with the h.brake off. Can be the cable binding or the lever housing gunked up.
      • Nj
        • Jan 2007
        • 3420
        cheers lads. if gods loves me i'll pick up the car later with a bill for a coupl eof quid for cleaning and greasing or something similar and hopefully not a new caliper
        1990 CQ20v
        • Acidburn
          • 13459
          Hopefully, I had this happen on a coupe gt as I was going down a hill, had a huge long tyre mark but it freed itself off so that was that
          • Nj
            • Jan 2007
            • 3420
            "the brakes were binding officer so I felt the best way to free them was to hoof it round a roundabout as quickly as possible"
            ....or is that another thread?
            1990 CQ20v
              sticky carrier guide pins are a likely option mate, just had to swap both of my carriers because of this
              • iain1067
                • 984
                guide pins can be removed cleaned and regreased, sounds to me like it probably could do with popping off, cleaning the brake pad carriers of rust and and old brake dust too, cheaper solution to try than just chucking a new caliper on. Have a look at the how the spring and cam work for the handbrake as well they do stick
                Iain
                  i've got a used but working caliper if you need it mate - you can have it for the cost of postage
                  • Nj
                    • Jan 2007
                    • 3420
                    garage just phoned and said I need the new caliper.
                    and saved my the man in.. erm.. pink by the looks of the avatar. oooh. lovely.
                    1990 CQ20v
                    • Acidburn
                      • 13459
                      Lol one of my old one's by any chance?
                      • Nj
                        • Jan 2007
                        • 3420
                        that could be a problem then cos this for the back of the 16v, not the s2. I haven't a clue if they're different.
                        1990 CQ20v
                          haha - yes Pete
                          as far as i know all the fwd cars shared the same rear calipers, this is off a fwd 20v (i think )
                          • Nj
                            • Jan 2007
                            • 3420
                            woohoooo!
                            1990 CQ20v
                            • Nj
                              • Jan 2007
                              • 3420
                              Alex, I don't think i'll need your caliper now mate but the offer is very much appreciated. I asked a guy I know if a particular scrappie has any coupes in and he gave me a decent pair of calipers for £20 he'd picked up ages ago on the off chance he'd ever have use for it.
                              So now - Anybody got any tips for changing the caliper over early in the morning? And I mean caliper related. not hints to wear a warm jumper
                              cheers
                              1990 CQ20v
