Slide Bolts
  • Davidsinclair05
    • Nov 2006
    • 365
    Slide Bolts
    Hi There Guys
    Does anyone happen to know where i could aquire a set of front slide pins for the brakes of my 3b?
    Just managed to sheer one off
  • Mikes2
    • 1704
    these are not available to buy seperately. Audi will sell you a carrier at £110 + vat.
    I've only ever been able to source rear guide pins from Ford dealers but not found a source for fronts.
    Mike
    http://www.s2-audi.co.uk
    • k.alle
      • Feb 2008
      • 801
      Woot, in Sweden we can get them for ~£8 inc VAT per kit front/back.
      Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
      http://www.garaget.org/?car=52877
      • Mikes2
        • 1704
        these ?
        Mike
        • Davidsinclair05
          • Nov 2006
          • 365
          not the bolts but the sliding bolt was seized and i used a slide hammer, sheared off the top but managed to still get the pin out
          • Davidsinclair05
            • Nov 2006
            • 365
            but i will order a spare set of rear pins, Thanks!
            • Davidsinclair05
              • Nov 2006
              • 365
              Anyone else on here that can help
              • aelred
                • Jan 2005
                • 761
                Have you tried Brakes International in Rochdale?
                Aelred
                • Nj
                  • Jan 2007
                  • 3420
                  • Home: Scotland Current: Finland
                  are the bolts or carrier likely to be the same as those on the front or back of a standard coupe? If so I can probably help you out mate.
                  1990 CQ20v
                  • Davidsinclair05
                    • Nov 2006
                    • 365
                    Sounds Promising but i think that the standard coupe had smaller front calipers but i have been known to be wrong
                    • Davidsinclair05
                      • Nov 2006
                      • 365
                      I tried Brakes International last week and the gent on the phone said not a hope in hell and to contact Audi direct as they couldn't even source a carrier let alone a slide pin
                      • Nj
                        • Jan 2007
                        • 3420
                        front calipers are definitely bigger on the s2 but that's not to say that the guide pins might not be the same. How do we check?
                        1990 CQ20v
                        • Davidsinclair05
                          • Nov 2006
                          • 365
                          Hmmm I will try to get a measurement of the diameter of the pin from my S2 today!
                          • Nj
                            • Jan 2007
                            • 3420
                            are you likely to be near glasgow in the next couple of days? If I get time i'll try to remove a caliper for you and take out the pins. If need be I can post them and you can try them.
                            1990 CQ20v
                            • k.alle
                              • Feb 2008
                              • 801
                              I'm sorry I have not been able to help you, I've been packed with work and my internet connection has been down for about 2 weeks, so I've only had my cell phone.
                              I'm at my mates place and catching up Internet wise.
                              I'm also in some deep financial troubles, and things aren't looking good.
