996's what hoses?
  • QuattroFever
    • May 2006
    • 1360
    996's what hoses?
    I've got s set of 996 or boxster s calipers on my ABY and i need new flexible brake hoses. I have rs2 (i think) hardlines after the flexibles.
    What hoses do I use?
    I seem to keep reading people getting custom braided ones made up but i have rubber on mine with no part no on them. Is there an off the shelf part for this or is custom the only way to go.
    Any help would be great. I ordered some goodridge ones off VAG parts who seemed to know what they were talking about but have sent me the wrong hoses after waiting for 6 weeks and now i need a fix in the next few days and I'm f***ed.
    Volcano ABY coupe
    Ant
  • Knight Rider S4
    • 3541
    You can use this option for your flexi as i am doing this,,each end has female connector (coupe rear flexi pipes)
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • europeanme
      • Oct 2005
      • 3817
      they are 996 mono's and RS2 hard lines on your beauty...and why are you lighting fires under the wheels!!...
      • terrybullwon
        • Mar 2006
        • 8782
        You could try www.speedflow.com
        You will need to measure what you want and then have it made in -3 with convex male adapters to M10 x 1.5 for the clipers and abs block.
        HTH
        James
        Chef
        • denniselbows
          • 740
          you could try http://www.brakehoseshop.com/ very helpfull bloke. work out which bits you need and make them up yourself, job done
          never set your expectations to high that way you are never disapointed
          • sjw185
            • 1175
            I just got some made from this guy on ebay fast delivery
            Got them made with banjo on one end female swivel on the other 460mm long.
            Cant comment on the quality as im offshore at the moment
            http://cgi.ebay.co.uk/205-309-gti-br...QQcmdZViewItem
            • sjw185
              • 1175
              another photo
              • terrybullwon
                • Mar 2006
                • 8782
                Steve out of interest, how much did they cost... If you dont mind?
                Chef
                • sjw185
                  • 1175
                  30sheets inc postage
                  But not seen them in the flesh yet. was going to order some for the rear if they are good.
                  cheers
                  • sjw185
                    • 1175
                    cheers
                    Oh for a pair Including bolts and copper washers for the banjo not sure if stainless thought will have to check
                    • Corey
                      Banned
                      • Sep 2003
                      • 2793
                      Plated BZP from the image, also as a note of caution the braid isn't covered so grit will work its way through and pierce the inner teflon. That's why Goodridge hoses come with an outer coating now.
                      The banjo fitting needs a 20 degree kick to stop the line straining under use, just be careful with the straight fitting.
                      Corey
                      01636 822288
                      • sjw185
                        • 1175
                        Thanks for the info will fit some heatshrink over the braid to keep it sweet
                        cheers
                        • denniselbows
                          • 740
                          just a word of worning after installing this type of pipe ends. once blead through and tested just go round all the pipes and recheck the tightness of the fittings on the pipes. one of the pipes i was suplyed whit my brakes leaked due to the pipe coming out of the fitting used the same style fittings when i made a replacement up and recheck after fitting and they did up a bit tighter, had no problems ever since. well not with the pipes anyway.
                          • QuattroFever
                            • May 2006
                            • 1360
                            Not fire it's cold air from the mr fusion used to power the flux capacitor and generate the 1.21 gigawatts. Now all I need to do is hit 88 MPH
                            Thanks for all your help guys this problem is now solved. Ahem, standard coupe flexible supply hoses.
                            Volcano ABY coupe
                            Ant
                            • europeanme
                              • Oct 2005
                              • 3817
                              yeah right!!.....
