Hi all,
Have a 94 s2 which has problems with the braking system -
The problem(s) are -
Red exclamation warning light flashes
Poor servo assistance (had to press very hard - sometimes twice to stop!)
Constant vibration through the pedal
"Grinding noise" when pedal pressed hard
Took car to an Audi dealer who said it was the "bomb", probably damaged by the previous owner who had put the wrong fluid in . . . . . they quoted me an arm and a leg So got local garage to fit this and PAS pump (supplied by Quattro corner) with fluids flushed and replaced with correct one.
This solved the problem in so much as the brakes now "work" however the vibration through the pedal continues as does the grinding noise.
Have been back to the Audi garage who have diagnosed the same faults as before claiming the bomb must be faulty and when asked said it wasn't a wheel speed sensor.
Does anyone else have any idea what else could be causing this problem, could other components have been damaged by having the wrong fluid in? I guess really what I am after is suggestions for the garage for other things to check . . . . . .
Oh and it fails the bomb "pump" test miserably )-:
Not the most mechanically minded so any help gratefully received
