Interesting ABS related finding
  • Interesting ABS related finding
    Since i did the 5 stud hub swap last week on my CQ, i've not had any rear ABS sensors in because i ended up destroying them trying to get them out of my old hubs.
    The ABS was randomly triggering, and not the safest situation to have with your brakes So i removed the two relays inside the ABS unit housing itself.
    Since then, my brake pedal has felt much much firmer and mroe positive
    Before i reomved the ABS relays, i had a spongy but effective pedal and I'd thought there was no doubt some air left in my lines since i fitted braided lines a few weeks ago, but hadn't bothered bleeding again because i'm fitting some refurbished front calipers in the next week or so, i thought i'd do it then one and for all.
    Since i've totally disabled the ABS, my pedal is much much firmer - any ideas why?
    Be a little careful. Mihnea had rather an interesting incident when he disabled his ABS. Swapping ends at 100+mph isn't the healthiest thing I can think ok
      what happened there?!
      i've removed both relays to disable the pump, i hope thats going to be ok?! I have the switcheable ABS so i thought that must be all that the switch did anyway?
      I'm scared now!! Cheers Andy
        Hummmmm...
        Dont think the 4wd has a brake balance valve like on 2wd cars, the abs does it all...
        You be going careful there bouy...
        Carlos.
          I'll be digging for ABS sensors on sat morning mate. hopefully have you sorted quickly.
          1990 CQ20v
            I'll still be bringing those two up with me when I come up ok mate
            along with all the other stuff for you
            Gonna have to start charging for a van to bring all your gear up.
              Ah - do you not need my sensors now Alex? Has Peter sorted you out?
              1990 CQ20v
                yes mate, sorry forgot to mention to you Noel. Pete has sorted me out.. or will.
                Pete - i can get you a pork pie and a copy of the sport to go on your dash if you like?
                  Lol its a deal if you can get me a cap like mr casey's avatar
                  I'll have to chat with you next week about everything i've got to bring up to you. Just so I don't forget everything this time, still suppose its one way of lowering the car till the h&r's are fitted
                    Hahaha yeah, hopefully that diff in the back won't be too much to control since you've got the only RWD S2 i the world as far as i can tell
                    That might make sence Carlos, its ok i've not been going mad as my alignment is way out after the hub swap anyway I've not really broken 50mph since then
                    I need to free up my tie rods this weekend so i can book it in for 4 wheel alignment asap, blow torch and GT85 at the ready!!
                      No worries mate. takes the pressure off me if i'm sitting with holes in my hands and crying cos I can't get them out.
                      1990 CQ20v
                          Hey, I did that to the Orificer's avatar because A) the Stig he ain't and B) he is just a Chav at heart.
                          I never thought he would actually adopt it, so please don't go posting things like that or he'll start thinking it's actually cool
                          Cheers n
                          Si
                          Subtle mods here and there
                          2011 A5 3.0 TDi - Lava Grey
                            It's all your fault Si. Best leave me alone and go bait some Avant owners. I know I'm not the stig, it was a laugh from the Donington track day that you should have come to play on
