I am looking for M12x1.5.80/90mm bolts for my porshe calipers ..Have fitted the 323 disc but with the 993 calipers i had to add 7mm shims to the bracket there for i need longer bolts . The standard ones are M12x1.5.65mm.Does anybody know where i would get them from ?..or is the there another model porsche/Audi that has longer bolts fitted to Caliper ?
From memory there's not much to hit so perhaps get them longer and let them stick through or grind the ends off. 5mm shouldn't cause any problems so go 80mm, that's a standard size.
It's often difficult to get what bolt suppliers call fine pitch metric!
Order some bolts from VAG for the Audi S8 with the brembo front brakes 99ish. They will do the trick as those calipers have a rather large boss.
