Help identify my front brakes
  • Trankelstein
    • May 2008
    • 119
    Hello,
    I have to replace the rotors and pads on my recently bought S2 -94 with RS porsche calipers in front. It´s just a jungle when i search the forums and i don´t know which brakes i have (large or small!?)
    Take a look at this picture and tell med which pads and rotors fits best.
    Regrads,
    Martin
    80 quattro 1984..... S2 sedan 1994
    Zermatt silver......... Brilliant black
  • Al Wyn
    • Nov 2006
    • 3746
    Cant see clearly enough in the piccy...take the wheel off...what size discs?
    S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
    • Trankelstein
      • May 2008
      • 119
      Have to wait for weekend for that.
      mvh Martin
      • s2_bo
        • Oct 2005
        • 6067
        Am liking the look of the rims!!!
        91 S2 coupé - RIP
        98 S8 - Luxury barge
        • Trankelstein
          • May 2008
          • 119
          Thanks s2_Bo! i like them too, Porsche replica 18x8,5"
          Now i have taken more photos,
          and
          It says Brembo on the inside and those rotors are 314 mm wide. As you can see those old pads doesn´t cover all the way out to the rim so i think i got the wrong ones. I also measured the play between rotor and caliper and it was 7 mm so i could clearly get 323 mm inside. Are there any RS2 large size rotors that fit with the S2 hub?
          • Mikes2
            • 1704
            If the discs are 314mm and the pads are not covering to the edge, the discs are too big.
            This means you must have standard RS2 calipers for the 304mm disc.
            Mike
            http://www.s2-audi.co.uk
            • Trankelstein
              • May 2008
              • 119
              Ok,
              Thanks for clarifying a bit, Mike.
              But, i looked and could see no shims on the calipers and i still have about 7 mm left to the inside of the caliper on both sides. Couldn´t it be the wrong pads or is it same for all?
              I have read of people having the small reds putting 6 mm shims under the calipermount to fit 314 mm discs, but if you could get up to 328 mm inside them already, why shimsing?
              • BRY
                • 3755
                Are they on RS2 brackets? If they were on SEAT IBIZA brackets you would already have a few mm of shims under them.
                The pads don't give much coverage on that disc, you need to check everything starting with calipers. Can you find any part numbers on them?
                • Trankelstein
                  • May 2008
                  • 119
                  I´ve figured it out
                  Now i know why i didn´t get the pieces together, someone has put the RS2 "small" pads with S6 314 mm discs, together with RS2 "large" calipers on my car. So now i´m getting the large pads and intend to use the S8 99-2003 323 mm disc, that´s what most use when putting big reds on the S2, right?
