Should be ok, but the width is the problem. GT2 6-pots are designed to be used with a 34mm disk, the same as the Cayenne. The S8 345mm disk is only 30mm thick, so keep an eye on you pad wear, as you wouldn't want much less than 2mm left before you change them. You don't want any of the pistons popping out.
GT2 6 pots with 345mm S8 disks - do-able?
doesnt the 996/323 disc have the same problem? as the porsches use 33mm thick discs. is there not some some sort of spacer yo can use? another thing, does anone know the piston sizes for the gt2 or cayenna calipers??
Ant91' Coupe quattro 20v - project
KW V2s and other goodies
now gone
03' BMW 330CI - Sold
08' A5 Coupe 3.0l tdi quattro - Sold
57' BMW 525d M Sport TouringComment
now gone
i'll get me coat
