hi i need a bit of advice about brake caliper alinement i have been having problems with me brakes ever since i went to the mono blocks with porsche discs. spent some time tonight measuring things as i have bitten the bullet and fitted some new discs and dont want to **** them up. from looking at how the disc runs in the grove in the caliper it is lined up spot on. but with the pistons fully back one pad is a tight fit and the other is realy loose so after doing some measuring i think the caliper is 1mm off centre. which when i measured the old pads one was 1mm less than the other. is 1mm enough to put a disc out it does look more when checking the gaps in the brake pads but i have only measured it to be 1mm. so how should i get the caliper inline measure the centre line of the caliper or put the pads in an make sure the gaps either side of the disc are equal?
your sudjestion please
dennis
dennis
