Flexing 996
  • bertman
    • Apr 2007
    • 1173
    • Current: United Kingdom
    Flexing 996
    Some of you will be very aware of the problems that I have had with getting my brakes working as they should,without result
    various people have looked at the car including some garages etc,and haven't been able to diagnose the problem.
    The car is now in a specialist garage down in dunsfold park where Top gear is filmed where a very knowledgeble bloke called Steve pointed out to me that the 996 calipers are actually flexing apart.
    The inner pistons on the bracket side remain still,tet the outer bank is physically moving out when the brakes are applied....by 2-3mm.Hence this might be causing my "spongy" pedal
    According to the mechanic this could be due to the calipers being overheated.
    remedies include:
    a different master cylinder
    strengthening the caliper itself
    Any help or suggestions please let us know
    Rob
    Ragussa green avant RS2+ spec
    Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
    Audi coupe gt-slow as hell but loads of character-sold
  • Rusty
    • 18953
    Interesting, the design of almost any calliper has to deal with the cleaving action of the pistons as they both exert a bending force on the centre section. If this is excessive then it indicates that either the calliper has been weakened in some way and thus the mateerial has been damaged or it's mproperties changed, or it indicates that one or more piston is not functioning correctly. I suppose you've just got to inspect the callipers as best you can. I've not seen the movement on my identical setup as I've not had someone put the brakes on whilst I've been specifically looking for that movement. Hope you get it resolved.
    • twoqu
      • Sep 2003
      • 3103
      Out of interest, what brackets are you using?
      • bertman
        • Apr 2007
        • 1173
        Seat cupra brackets (machined down of course)
        Rob
        • s2driveruk
          • 12696
          that doesnt sound good at all....are the ones u have black or red? If red are they a dark red or the normal colour (if on original paint) Dark red would suggest they have been worked hard.
          1992 3b S2 Coupe
          • bertman
            • Apr 2007
            • 1173
            Andy if you had seen how much it did flex you would be very surprised if not a bit worried.
            Because we are running different master cylinders to what was originally intented,there might be a case of our set ups running a higher load on the pistons.But no one has reported anything like this before
            But I would deffo go would with the idea that the caliper has been weakend somehow.
            He is going to call a mate of his at brembosport to find out some more info.
            Rob
            • bertman
              • Apr 2007
              • 1173
              They are black,so its diffucult to see if they have been cooked
              Rob
              • twoqu
                • Sep 2003
                • 3103
                Well I guess its a possibility that removing that much from a bracket designed to be thicker might be a contributory factor. I doubt when it was designed it was massively over engineered.
                Of course that flies in the face of all the collective experience on here!
                I would try and eliminate the caliper first by a precautionary rebuild just in case those pistons are seized.
                Can't see how you could strengthen the caliper. Wasn't the idea behind the monobloc that it was stiffer than a two piece bolted one. Think I have seen some arguments about this on the Stoptech site.
                • bertman
                  • Apr 2007
                  • 1173
                  The side closest to the bracket doesn't move just the outer side,pistons etc were checked and deemed to be working ok.
                  but a rebuild could be a precautionary measure
                  Rob
                  • twoqu
                    • Sep 2003
                    • 3103
                    There you go:
                    Actually I have seen the larger 996TT monobloc used in a Movit conversion that used a 12.9 cap screw to hold the pads in rather than the usual pin!
                    • twoqu
                      • Sep 2003
                      • 3103
                      So can those inner pistons be retracted? If they can then obviously they are not seized. Depends what you mean by not moving.
                      • bertman
                        • Apr 2007
                        • 1173
                        thanks mate will have a looksie at this
                        Rob
                        • bertman
                          • Apr 2007
                          • 1173
                          Inner pistons can be retracted,two were a bit sticky but have been sorted.All I was saying was that the actual body of the caliper which the bracket is bolted to does not show any signs of flexing,just the outer bank physically moves,can be seen easily when foot pedal applied.
                          You'd expect to see a split or crack down the middle of the caliper the way it was moving
                          Rob
                          • denniselbows
                            • 740
                            well i think you have just summed up what has just happened to me. with the engine off the pedal was rock solid started the engine and with the extra presure from the brake booster hydraulics the pedal went spongy i bet i have the same thing as you . have you had to replace many discs? as i am on the second set in 12 months of up grading and they are pretty much ****ed as well .
                            never set your expectations to high that way you are never disapointed
                            • twoqu
                              • Sep 2003
                              • 3103
                              Have you ever replaced the wheel bearings in your ownship of the vehicle?
