RS2 Poor Handbrake Adjust? How to? Help
  • UUUdirs2newcastle
    • Apr 2008
    • 655
    Its 12:15 at night, im in the middle of fitting a set of Bilsteins, H&R Springs and Poly Bushes, and I thought I might aswell adjust the Handbrake while I lie in the mud, water, dust, Aspestos, grime etc etc.
    Can I stick a spike in the hole on the drum and adjust it like other drum brakes, or do I have to do something much harder that quite frankly I cant be chuffed to do at this time in the morning!
    Please help before I put my car back together again!
    BTW, these RS2 H&R springs aint half low! Better watch out for hedgehogs!
    So how do you do it then?
    As per your other boast, sorry post.
    How did you get on?
    Thanks and kind regards.
    • A80Avant
      • 10873
      • Country: Greece
      you can adjust it through the hole in the drum to work with 2 clicks of the handbrake lift,but i dont know which way you are supposed to turn it to.Mind though that if the pads are worn or the cables as well,you wont manage anything..
