UFO's replaced with Porsche 6 pots
  • K7ERG
    • 1711
    I am looking for any info people have on this. If any............................or willing to share.
    If not i am looking at designing a bracket that will work.
    I now have spare UFO struts, calipers and pads. Just need to buy the discs i am looking at fitting then the rest will be a custom bracket.
    The discs i am looking at using are either the RS4 discs or the VW Phaeton.
    Any help or info welcome.
    Craig
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
  • Knight Rider S4
    • 3541
    Craig if you give me one strut, disc and caliper i will get a friends brother from technocut to fabricate a carrier for you..(homer prices)
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • K7ERG
      • 1711
      will do
      07947385043
      • GazzaG60
        • 4133
        depends what 6 pot.
        i have GT2 6 pots they require a differnt bracket to say Toureg/Q7 6 pots. also the caliper from the audi/q7 is a lot heavier and has a cast carrier into it.
        im also using 993TT discs. the 350mm from the toureg require me a fork lift truck licence to get from my car to the garage.
        • K7ERG
          • 1711
          Porsche cayenne 6 pots
          365mm x 34mm discs
          07947385043
          • merlin's S4
            • Jan 2005
            • 1539
            Isn't the biggest problem with the ufo strut that the hub is too close to the strut to allow the disc to sit properly? You may need a spacer to push the disc out before you design a bracket.
            Can I ask why you want to use a ufo strut? Would it not be easier with the HP2 strut?
            • spink
              • 4382
              any chance you could stick a picture up of a ufo strut with the disc taken off,can't say i have seen one before.
              • K7ERG
                • 1711
                Spink - Will do once i get out to my parents house.
                This is why i am asking for suggestions /ideas before going ahead making a bracket for the UFO's. I have HP2 struts sitting so might just use them if too much hassle.
                The reasons i would like to keep UFO's it would save me removing the strut, swapping the bilstein suspension over and get the tracking all setup again. (Tracking will probably need done with either setup)
                I am looking at the 365x 34 mm Discs as said but
                What are the smaller disc dimensions used with the Porsche Cayenne 6 pot caliper?
                What is the minimum wheel size they fit under?
                07947385043
                • merlin's S4
                  • Jan 2005
                  • 1539
                  The bolt on setup with the HP2 struts uses a 330x32mm (I think) and fits under 17s.
                  • K7ERG
                    • 1711
                    330 x 32mm discs from a merc?
                    Craig
                    07947385043
                    • topsparky
                      • Oct 2005
                      • 2014
                      Craig
                      merc v8 can't remember which one
                      don't forget the centre has to be bored
                      out to 57.1mm so it will fit on the hub
                      1. SHORT SHIFT KIT
                      2. PORSCHE CAYENNE CALIPERS
                      3. H & R SPRINGS
                      4. BILSTEIN SHOXS
                      5. NEW BUSHES AND HP2 STRUTS
                      6. UPRATED HIGH OUTPUT COIL PACK
                      7. ,3" turbo back s/s/ exhaust
                      8. fmic fitted
                      • K7ERG
                        • 1711
                        Anyone used the bigger discs with the HP2's?
                        If so what was done.
                        Craig
                        07947385043
                        • K7ERG
                          • 1711
                          07947385043
                          • K7ERG
                            • 1711
                            anymore info on either the smaller discs or the 365mm discs. What is needed? Brackets etc. For the hp2 strut.
                            07947385043
                            • spink
                              • 4382
                              Have you abandoned the ufo project? I just bought a nice urs4 this week that has skanky ufo discs,don't think my mot man is going to like the look of them.Craig (or anyone) have you got any decent used ones?
