I want to convert my 1991 (non-turbo) CQ from its 4x108 to the S2's 5x112 bolt pattern and I need the part numbers for the front and rears. Also, if you know the cost and best price to get them from. Thanks!
Need part number for S2 front and rear hubs...
Originally posted by snopyroI want to convert my 1991 (non-turbo) CQ from its 4x108 to the S2's 5x112 bolt pattern and I need the part numbers for the front and rears. Also, if you know the cost and best price to get them from. Thanks!
Front 895-407-615A
Rear 895-501-653
Not cheap from the dealer. You least expensive solution is to get them from a breaker.
They will go in as straight replacement for the existing hubs. You will need to change the bearing, as usually taking out the hub destroys the bearings.
But since you are in the sunshine state like me, access to those hubs are difficult. If you can wait a while someone on this site usually puts parts up for sale. If not, you can try Alex at Euro-Price, but usually runs over 600 USD for the set.
GregThey can have my car when they pry my cold dead fingers from the steering wheel.Comment
Mine were from a breaker and so I don't know the part numbers. Greg has posted the easiest option of Europrice. My hubs were a little bit corrodedOriginally posted by martinjsstick insect may be able to help you , he's converting his at the moment.
on the outer edges. I think the hubs had been at the back of an Audi breaker for years and were a bit worse for wear.
Having a lot of blasting done and will post pictures.
DavidComment
