Hi guys!
First of all, I don't own a S2
so please bear with me.
If You don't know, Citroens use hydraulic pressure to power brakes, steering and for suspension.
But brake pedal travel and brake feel or better put applying brake force in emergency situations is a PITA.
So I was thinking of putting something like Audi's system on. To still use hydraulic (LHM) pressure for brake assist but have longer pedal travel and be able to more accurately apply the force.
So can anyone please explain (some photo material preferred too) how does it work?
Does the system work the same way like vacuum assisted boosters only instead of negative vacuum, Your system uses positive hydraulic pressure?
Can LHM oil be used in such system?
Thanks in advace!
Regards
Ziga
so please bear with me.If You don't know, Citroens use hydraulic pressure to power brakes, steering and for suspension.
Thanks in advace!
Regards
Ziga
