Check out the 8E0 rear brake upgrade thread... I researched this originally for the Coupe but had to alter it along the way. If you have deep pockets then you can fit a 300x22mm setup from the B7 S4/Cabrio. The discs, carriers, calipers and pads bolt straight onto the Avant or Sedan... Some little modification is required for how the handbrake cable attaches, but nothing major. s2avant has done it on his car... Search the forum for part numbers and post back here if you are unsuccessful with the search.
