RS2 Rear Brakes
  • paulsf
    • Oct 2006
    • 71
    RS2 Rear Brakes
    Folks
    Can anyone confirm if these are a direct fit for the standard RS2 rear discs please?
    Porsche 928/944T rear rotor (951 352 041 01)
    quoted from another thread;
    Both 928 and RS2 discs seem to share:
    299 x 24 disc size
    5 x 130 bolt spacing
    71mm height from the back of the disc to the wheel mounting surface
    180mm inner diameter inside the "hat".
    I can get these for £130 each inc VAT which is a darn sight cheaper than Audis discs. I know they are non floating discs but this hasn't been a problem on the fronts since they were swapped over.
    I can't find a post confirming if these 928 discs fit so would appreciate some input!!
    Paul
    __________________________________________________ ______
    RS2 Ragusa Green and a Sunbeam Lotus for the summer weekends.
  • saltinot
    • May 2004
    • 1946
    I've done a lot of research recently searching for an RS2 rotor option that I could source here in the US via Porsche. The rear rotors on the later 928s are the ones and that's the part number you give above. I've seen some mis-information on the web about how a 968 rotor is the same.....it's not even close to fitting.
    The RS2 and the 928GTS share the same rear caliper too. The only difference is color.
    • paulsf
      • Oct 2006
      • 71
      Hope it's right!
      I can get the parts cheapish but as they are special order they can't be returned.........
      Paul
