Hi, I have in my possession a set of front gt3 calipers 996 351 429 10 / 996 351 430 10 and have been trying to work out what i need to fit them to my s2. Has any one got any guides on whats needed? From what i can tell the front brake disks from the W8 passat are a suitable option for the disks has anybody tried these or got a better option? Also I will be making the brackets myself out of mild steel so if anybody has any dimensions for the brackets then that would be much appreciated
. This upgrade is obviously still in the planning stage and i wont be trying to have it fitted properly till after winter when i get my 18" summer wheels back on.
Help with gt3 caliper upgrade
You obviously have no expirience tn the break upgrade and your making the brackets your self? I would say thats brave!
Engine mods etc... ye ok if it goes 9 times out of 10 the passanger will be ok, think at the forces when trying to stop at 100, 125 or even 150+mph!!!!!!!!!!!!!!!!!!!!!
Just my opinion tho!Probably the longet S2 project in history EVER!
Yes you are probably rightYou obviously have no expirience tn the break upgrade and your making the brackets your self? I would say thats brave!
. I just fancied i bit of a project. I can get the brackets made up professionally if need be. But at this point I just need advice as to what parts have been tried and tested for this brake setup
1994 Indigo Blue S2 coupe
1994 80 Avant 1.9 TDI
2005 Yamaha Fazer 1000
1953 AJS Model 18SComment
i have gt2 6 pots.
you need
a hose kit
discs of choice. i use 993 tt with custom bells
pads. i picked the cheapest to start with red stuff. around 120 a set of fronts. they work.
toureg pad retaining kit for 6 pots.
brackets for calipers.
bolts to hold it together. use RS2.
be careful the spacing on 6 pots is not the same as 4 pots for the bracket.Comment
Thanks for the input so far
. It 4 pots that i have. If anyone with 4 pot GT3 calipers could let me know what disks they are running I would be grateful. I am looking for a off the shelf disk to try and keep the costs down.
So 360mm disks are the baby's to go for? That's good news as I was not sure what would be best. You wouldn't happen to have the dimensions of your custom adapters available? pretty please
Hello, i have installed the 996.351. 429/430 Calipper with the A8 360x34mm disc on S2/3b. It work's verry well, the brake it is like the Porsche GT3 (i have tested on Hockenheimring)
Rearbrake is A8 335x22mm with adapters and Girling 41/43..
Adapters i have made by an brake spezialist can be ordered...
ThomasComment
From what Audi are the Girling 41/43? S4/S6 C4?Hello, i have installed the 996.351. 429/430 Calipper with the A8 360x34mm disc on S2/3b. It work's verry well, the brake it is like the Porsche GT3 (i have tested on Hockenheimring)
Thomas
Standard I thought these calipers were used on 276mm discs, but 335mm is quite a big jump. Do you have pictures of your rear-setup please?Comment
I think Kev (aka Bambridge) is looking at doing a mounting bracket for the 429/430 Caliper...
I know I measured up a set of calipers for him...
He does do a bracket for the 996-351-425 caliper but the holes are 130mm not 140mm as for the 429/430 set up..
Ask him the question!!!
Would save one hell of a lot of work....Comment
