Seized bolts!!
  • robert_n
    • Aug 2008
    • 357
    Seized bolts!!
    Any suggestions on the best way to loosen the mounting bolts on the front calipers? Ive given them liberal coatings of WD40 and left it to soak in but it hasn't seemed to do the trick.
    I am hesitant to put a blowtorch (not that i own one) anywhere near something with rubber seals/pipes etc but i have heard that is a good way of getting bolts off.
    Thanks for your help.
  • add
    • Jan 2008
    • 931
    could you not get hold of an impact wrench?
    on occasion i've found striking seized bolts with a hammer can brake the rust-not sure if that's wise where brakes are concerned though
    It's a love/hate relationship with the S2,i love it,it hates me
    • Acidburn
      • 13459
      impact sockets with a breaker bar and extension normally does it for me, have they rounded off?
      • goodall
        • Jul 2008
        • 810
        dont think using a blowtorch would cause much an issue since the seals on the calipers are high temp anyway and you aint using the flames directly at the seals
        have you tried air impact wrench on them, how i get most difficult bolts off, bent a draper expert t-bar on a bolt ended up un-doing with air wrench, should seen look my friends face as i destroyed his t-bar, i actually though was just deflecting untill point were it went really plastic
        edit, i type too slow people got in there before me
        • AndyP
          • 6049
          Turn the wheel onto full lock so you can get a huge breaker bar in there.
          • robert_n
            • Aug 2008
            • 357
            Sadly I don't know anyone around here with an impact wrench and I don't know any of the guys in the workshops at work never mind getting my car in through the security gates.
            Nope they haven't rounded off.
            Is an impact socket any different to a normal socket?
            Ive tried giving the breaker bar i have a tap but its not the best, as its 3/8s so i am using a 3/8-1/2 converter which my socket is, this means the is a bit of play when you give it a 'tap' with the hammer.
            • S-Express
              • Nov 2006
              • 1133
              I had to do this 2 months ago.......had to remove hub and weld 16mm bolts to the caliper carrier bolts and then get a big spanner on the 16mm bolts whilst holiding the hub in a vice.
              Good luck!
              p.s. both sides were the same
              • Knight Rider S4
                • 3541
                and beast it
                93 S2 Avant Parting
                91 URQ RR
                02 A4 tdi Avant
                • Fat Audi 80
                  • 10547
                  If you ain't got the right tools you will struggle. You need you 1/2 sockets on your 1/2 breaker bar then gain the required access and put all your weight on it fast and steady as you can. That WILL crack it. (Or your tools...)
                  Good luck.
                  HTH
                  Steve.
                  The Perfectionist
                  • robert_n
                    • Aug 2008
                    • 357
                    Thanks all.
                    Oh well, looks like I am off to the tool shop tomorrow to get the biggest breaker bar i can. Hopefully a dab of copper grease will make this much easier next time (which wont be all that long as I'm guessing my new EBC pads will last less time than the OEM ones they are replacing).
                    • AndyP
                      • 6049
                      Wait until you have to get the caliper carrier bolts undone, poxy cap head screws
                      • Dpicariello
                        • Mar 2006
                        • 621
                        Robert,
                        I will brink my breaker bar to work tomorrow. If you can get to AP Racing either at 1pm or 5pm then you can borrow it (although I'd need it back for the weekend).
                        It's only a 2ft bar but it did the job with mine. I did use an electric impact gun on my caliper bolts to crack them loose but if you can get in there with this bar (which i did) then you should be able to undo them.
                        I can't remember what socket it is but can lend you this too if someone reminds me.
                        Dan
                        • Knight Rider S4
                          • 3541
                          17mm impact socket does the job
                          93 S2 Avant Parting
                          91 URQ RR
                          02 A4 tdi Avant
                          • robert_n
                            • Aug 2008
                            • 357
                            Wish i'd seen this post earlier, makes access MUCH easier.
                            Originally posted by S2Central.net
                            New pads from Audi normally come with a set of four caliper mounting bolts. These are pre-coated with a thread-locking compound. If buying after market pads then don't expect to get the bolts included. It is wise to renew the caliper bolts (321 615 141 ) at every pad change.
                            Replacing the front discs is a little more problematic on the S2 as it requires the tightly mounted caliper carrier bracket to be removed. These can put up a good fight. The two 19mm headed M12 bolts which hold the front caliper carriers into the hub are subject to corrosion so one needs to be very careful in removing these bolts. The carrier mounting bolts ( N 901 740 01) should of course be renewed when the discs are replaced.
                            Can somone confirm these are the correct part no's for a '94 Avant as my calliper carrier bolts have a 17mm hex.
                            Thanks all!
                            Especially Dan for lending me the breaker bar. (any chance i can return it before work 7:45 ish tomorrow?)
                            • Graham
                              • 1622
                              An impact socket is usually single hex, where as a normal socket is double hex:
