Hi there what is the standard S2 vented front disc measurments please?
S2 standard front disc size
Tags: None
276x25 from memory, but http://s2central.net has the definite right answer in tech sectionPaul Nugent
Humour me for a min then chaps....
If I have a set of 4 pot AP calipers that will fit the standard S2 disc and each of the 4 pistons measure 40mm diameter.
How do I calculate what braking force this will give me in comparison to a set of porsche calipers?
I understand that i will have more pedal movement...Comment
1st step assume a hydraulic pressure, say 100 Pascal (makes handy to work out)
so if 1 pascal is 1 newton per meter, then F=p*a
for the new calipers 100*[(4*40)*10^-6]=0.016
then you take the force and find the torque T=Fl (l is disc diameter/2)
0.016x(187.5x10^-3)=0.003Nm
do the same for the porsche calipers and disk size and then divide 10 (value given for ap systems performance) by 0.003 (ap number)= 3333.3 and multiply by the torque got by porsche system, if is more than 10 its better less its worse
this all assumes that you will get friction of 1 using the brake pads which isnt going to happen and that all the pressure is applied at the edge and also the pad material is the same, but its good for comparing braking force
oh yea and more pedal movement means more slave area thus more pressure
edited because i made a misstakeLast edited by goodall; 20 January 2009, 20:44.Comment
That was heavy reading after a long day at work.....1st step assume a hydraulic pressure, say 100 Pascal (makes handy to work out)
so if 1 pascal is 1 newton per meter, then F=p/a
for the new calipers 100/(4*40)*10^-6=625000
then you take the force and find the torque T=Fl (is disc diameter/2)
625000x(187.5x10^-3)=117187.5Nm
do the same for the porsche calipers and disk size and then divide 10 (value given for ap systems performance) by 117187.5 (ap number)= 0.000085333 and multiply by the torque got by porsche system, if is more than 10 its better less its worse
So as anyone got the figures for a porche setup???
