Is there any difference between s2 3b and rs2 brake master cylinder? i checked etka. it says same diameter pistons in all. how about the servo? the etka says different part numbers, but it looks same.
do you know anything about this?
We've been through this in the Brake Porn thread by S2Avant there is no difference even though they have different part numbers.
i know both have 25,4mm front piston in the master cylinder, but how about the rear. i just installed the rear porsche ones and i can pust the break pedal 2cm deeper. i think there is difference in the rear piston between rs2 and s2 3b.
