RS2 hand brake cable routing
  • saltinot
    • May 2004
    • 1946
    Does anyone have a picture detailing the routing of the hand brake cable where is goes through the rear control arm? A detailed description would do also.
    The RS2 cables I have do not have the plastic tube, a la S2, for routing through the control arm. For what I can see, which isn't much from the US, is that the cable routes above the arm? Is there one of those rubber coated clamps holding the cable in place?
    Cheers,
  • rs2315
    • Jun 2006
    • 867
    This might help.
    rs2315.
    • saltinot
      • May 2004
      • 1946
      Yes it does!
      I had found this in the workshop manual, but your picture helps me to see it in real life.
      I think these are the parts I need.
      N 905 756 01 dual clamp 2
      N 010 216 12 screw, hex. hd. M6X18 2
      N 022 148 11 hex. nut, self-locking VM6 2
      This parts aren't shared with the S2. So using deductive reasoning this should be the stuff. Anybody with an RS2 know if these parts look like what is on your car?
      Cheers,
      • autohausdolby
        • Aug 2009
        • 87
        Thanks for that - I've just ordered those as my hubs have just turned up from Germany
