Big Brake handbrake solutions..
  • kingfishers2
    • Feb 2007
    • 756
    Has anybody tried these http://www.jegs.com/p/Wilwood/757779/10002/-1 I think they might be a useable solution to the lack of handbrake when the monster brake conversion is carried out, obviously suitable brackets would have to be made and maybe some tweeking of the handbrake cables, would be interesting to here feedback on this if anyone is running a similair setup.
    Alex
  • topsparky
    • Oct 2005
    • 2014
    i don't think they fit on s2 rear discs i don't think they go wide enough
    i sure someone will put me right
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    8. fmic fitted
    • anton
      • Jan 2005
      • 802
      says they go all the way to 20mm , and there is a 12mm set too so would be spot on for the s2 (10mm) but i think most if not all of the bigger vented rear upgrades are 22mm so not rly an option for an uprated system. may well be wrong about the 22mm fpor the bigger ones though.
      Ant
      91' Coupe quattro 20v - project
      KW V2s and other goodies
      now gone
      03' BMW 330CI - Sold
      08' A5 Coupe 3.0l tdi quattro - Sold
      57' BMW 525d M Sport Touring
      • driftin jo
        • Sep 2007
        • 2222
        Alex
        These would be better , will do 20 -32 mm wide disc . http://www.compbrake.co.uk/COMP%20R3...Mechanical.htm
          What conversion doesn't have a handbrake solution?
          • martinjs
            • 3205
            Monoblock
              Yeah but silly to do that on a Coupe when a solution is already out there with a handbrake!
              • martinjs
                • 3205
                Yes but for some its not big enough
                • kingfishers2
                  • Feb 2007
                  • 756
                  Unfortunatly or fortunatly which ever way you look at it! i have the mono block rears so im looking to try out some ideas soon, a spot caliper seems like the best solution and safest, i have seen another solution in the flesh but it didnt fill me with confidence.
                  The only negative thing i have heard about spot calipers is they can seize if used on overly hot disks, whether this is true or not i dont know.
                  • martinjs
                    • 3205
                    If i was doing it i'd use a monoblock and one of these from brembo and mount them both off one bracket.
