Some questions about brake upgrades
  • Rozvor
    • Feb 2009
    • 10
    • Country: Spain
    Hi
    First: sorry for my bad english
    Second:
    Is time to upgrade my brakes, my car begins to brake really bad with this power
    - I have a 16" wheels with an interior of 380mms
    - I think about the 322x32 RS2 discs with their calipers
    - But I learn in the forum about the 314 discs of the A8 and the 323 discs of the S8
    - Are the 314 discs compatibles with the RS2 322 calipers?
    - Any other calipers compatibles with the S2?
    - With the 380mms of wheel interior...any other options?
  • Henkjan
    • 1705
    calipers from a Boxter with discs from an A6q should fit in 16"
    • Rozvor
      • Feb 2009
      • 10
      • Country: Spain
      A6q year? What disc diameter have?
      • Rocco
        • Aug 2007
        • 6393
        • Country: Spain
        Hola compañero,si quieres yo te puedo vender un kit completo para llanta de 16",es lo mas gorodo que puedes montar en nuestras llantas.
        son discos y pinzas de Mercedes 304x30,tambien con sus soportes para acoplar plugg and play en nuestros coches,vamos...preparado para coger y montar,ademas tanto discos,como pinzas y pastillas estan como NUEVOS
        a todo esto ,de donde eres??
        PD: in english, i am offering to you my Mercedes 16" full brake upgrade.... 304x30 with discs,calipers and brakets...
        • Henkjan
          • 1705
          312x25mm discs (Audi A6 avant 3.0 quattro 01-05)
          and you'll need an adapter to fit the calipers of course
          • curlyks2
            • 1069
            You might need 17 inch wheels for the RS2 brake setup - that's certainly suggested over at the S2Central brake section. Take into account running costs too: RS2 calipers will suffer from plate lift at some point and you'll have to get them stripped down and rebuilt; even with good people on the forum it's money. Might be better to get something which doesn't have the plates in the first place - 996 calipers maybe.
            Ck.
            Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
            • gavs20v
              • Sep 2004
              • 3057
              ive just put a set of big red calipers in the for sale section if your interested
              Gav
              S2 Cabriolet.........
              • Rozvor
                • Feb 2009
                • 10
                • Country: Spain
                Ck.
                Thanks for all the info
                Because the ET of my wheels I won't need wheel spacers to mount the RS2 "big calipers"
                One question more
                - S8 323 discs are compatibles with RS2 "big calipers"? And with the 996 calipers?
                If are compatibles probably I buy the calipers of gavs20v and the S8 discs
                Regards
