Hello. I am new in here , and from Norway so my english is a little like Petter Solbergs..
Problem: engine is running , pump brake pedal 8-10 times = warning lamp screams.
Waiting 10 sec. lamp dies.
Installed new servopump , new switch ( mounted on the brake pump,with 2 wires.)
Bleed the system!! New pentosin oil. New brake fluid.
Measured the pressure, 145 bar and stabil, no leaks,
abs working fine.35 pump on pedal when engine shut off. Bomb ok! I welded on a "filler thing " and inserted 90 bar nitrogen.Works perfect.Used it a year !
(Seems like the pressure comes to late back/ to slow when pumping then pedal.)
no lamp when wires are taken off.
Need help.
/ R
Need help.
/ R
