Brembo Six Pots
  • martinjs
    • 3205
    You have a pm ant.
    • S2 Ant
      • 3682
      Thanks Martin!
      Will def look in to further after my holiday
      Ant
      2011 Kawasaki Z1000
      • S2 Ant
        • 3682
        The Cayenne def uses 6 pots and discs are 350x34 or 330x32 so as long as they can have the PCD altered by machining (im guesing that can be done??)
        Then these would be very good?
        Ant
        2011 Kawasaki Z1000
        • Dr H
          • 1175
          Originally posted by S2 Ant
          Dr H, would you be able to find out what the part numbers of these Brembo's are from that specialist? Can then see where they come from and look in to this further.
          Custom carriers are more than likely needed, just a case of whether or not someone like Martin, could or would be able to make several as i recall it was v time consuming to do the ones he done previous.
          You have a PM
          Ex 1994 Avant - now driving a Lotus 340r
          • S2 Ant
            • 3682
            No i dont :S
            Ant
            2011 Kawasaki Z1000
            • S2 Ant
              • 3682
              AH ha, do now LOL
              Ant
              2011 Kawasaki Z1000
                Only issue may be with the hat height since 4x4's tend to have larger hats on the discs.
                • Dr H
                  • 1175
                  No one said what the calipers were off. Those of you who have contacted them - what did they say?
                  • S2 Ant
                    • 3682
                    Ive not contacted them, but the Porsche site says that the Cayenne uses 6 pots and the above discs.
                    Hadnt thought of the hat height issue!!
                    Doh... too many variables !
                    Ant
                    2011 Kawasaki Z1000
                    • S2 Ant
                      • 3682
                      Was looking at these again this morning cos there was a Cayenne next to me in the traffic, there callipers are mounted in front of the suspension leg, so presumably would need that crossover pipe changing around etc as per the same as some other porsche callipers.
                      Going to enquire about the disc dimensions when i can
                      Ant
                      2011 Kawasaki Z1000
