Pads for 968CS calipers...?
  • JamesHarrold
    • Feb 2008
    • 245
    Need a little help with finding the right pads for my Calipers.
    I have been told that the calipers I have are 968 club sport (black). Think they are the same as the RS2 calipers....but cant be sure.
    The pads are getting a bit knackered so been trying to get hold of some ferodo ds2500's.
    Spoke to Steve at Questmead...really nice guy and very helpful. Ordered ferodo FCP560H for the 968CS caliper and when they arrived they didnt fit....But noy by much, only difference was that the centre of the back plate where the locating spring clamp closes down on the pads was too short therefore didnt touch the pad at all. Tried all night but couldnt get it to work.
    Does anyone have any ideas which pads would fit these calipers....?
    James
  • Mikes2
    • 1704
    I know the calipers and they're not 968 cs. They're Porsche 911 993 calipers. If you order 968 cs pads, you must specify they are M030 option versions. Same pads also went in the 928 S4
    Not the same as RS2 pads either as they use a thinner amount of material
    Mike
    http://www.s2-audi.co.uk
    • JamesHarrold
      • Feb 2008
      • 245
      Hi Mike....I see....! MO30 versions
      Would make sense as the 968cs pads dont want to go in at all.
      Will enquire about MO30 option pads with questmead.
      James
      • JamesHarrold
        • Feb 2008
        • 245
        Can anyone who has/had these provide a part number for pads to fit these calipers....?
        I (and half the friction specialists in the uk) am really struggling to find pads that fit..!
        Cheers guys
        James
        • GT500
          • Jun 2006
          • 2181
          Just draw around the old pad and fax it to Qestmead.
          Make sure you haven't a load of corrosion between pad plate and caliper, thats what can stop even the correct pad fitting!
          Rob..
          87 UR 20v ABY
          97 S6 Avant
          • JamesHarrold
            • Feb 2008
            • 245
            Yep...have done that....pics, diagrams emailed to them etc and still no joy. They even said they had spoken to textar and the part number from my pads didnt exist....!?
            • sam80quattro
              • Oct 2006
              • 1496
              ever get them sorted? im having similar problems
              • JamesHarrold
                • Feb 2008
                • 245
                Yep..they are for the 968cs MO30 option & 911 (993)
                Are real pita to source though....In the end got some original textars from here...
                http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
                Hope this helps Sam.
                James
                • curlyks2
                  • 1069
                  My brake pad catalogue lists this shape/fitment of brake pad as being fitted to...
                  911 (964) 3.3 Turbo front
                  911 (964) 3.3 Turbo S front
                  911 (964) 3.6 Carrera RS front
                  911 (993) 3.6 Carrera front
                  911 (993) 3.6 Carrera 4 front
                  911 (993) 3.6 Carrera 4S rear
                  911 (993) 3.6 Turbo 4 rear
                  911 (993) 3.6 Turbo GT2 rear
                  911 (993) 3.6 Turbo GT2 4 rear
                  911 (993) 3.8 Carrera front
                  911 (993) 3.8 Carrera 4 front
                  911 (993) 3.8 Carrera RS rear
                  911 (993) 3.8 Carrera RS 4 rear
                  928 4.7 1985-1986 front
                  928 5.0 1985-1992 front
                  944 2.5 Turbo 1988-1991 front
                  959 3.0 1987-1991 front
                  and last but by no means least...
                  968 3.0 Sport (M030) 1992-1995 front
                  The Ferrodo DS Performance code for this pad appears to be FDS560, and for DS2500s use FCP560H - even though the first post says this doesn't actually fit. Both available according to their website from Motorsport World (linky) (NCTS etc).
                  Although extraordinarily similar in shape, these really are different to RS2 pads which are 1mm less tall and 2mm less thick (but with the same width), if the dimensions in the catalogue are right.
                  Happy hunting.
                  Ck.
                  Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
                  • WabTheKing
                    • May 2004
                    • 2567
                    what rob ment was they will make you a custom pad to the drawing,
