Not much to say but designing it and figuring out how to make it fit nicely was a pita. The whole car has been swapped over to AN fittings so I made all my own lines out of cunifer with stainless ferules and nuts. The tubing was single 37 degree flared. It's safe to do so on cunifer. The hiccup is that i had to loose the stock cigerette (fag?
i remember that from trainspotting) lighter spot. I'll be moving to in front of the rear ashtray. I don't have alot of pictures but here are a few:
) One thing which i doubt now - mine also has spoons installed instead of original seats. and i have found that with shoulder support it is not convenient to use handbrake in it's original position, therfore i am thinking of mmoving both tilton and hb further from their original positions. that is another story as the car has to remain with the interior (mostly
) anyway, thx for this tread, once i'm back to thae garage i will tru to consider your configuration for tilton, as mine already has V8 diff fitted
Just need to look for all these plastic plastic covers now
