Big brakes questions..
  • GazzaG60
    • 4133
    to my knowledge the cayenne, q7, toureg and Gt2 all share the same shape caliper. what i have seen different is the mounting lugs are part of the caliper for a q7 6 pot. they are slightly heavier than the gt2 caliper and use different pistons. maybe thats due to the ceramic disc option. my gt2 ones have funny caps in the pistons
    i use the 993tt disc up front still on standard rears but gonna fit the 280mm conversion soon. got the 4 pot rears. they dont look wide enough for a thick rear disc. expect different to the cayenne maybe weight related
    • aronmatic2
      • 2129
      • Country: Hungary
      Originally posted by yavor20v
      Thank you! I thought that 365mm RS6 discs will fitt, I don't know?? You're saing 350 maximum...i'll try after the sea trip
      i tryed the rs6 discs, i bought, but its impossible to fit right.
      yes. if you want 350mm, you need to make some mods on the calipers.
      Real carbon parts for S2 and RS2. Check Carbondesign on facebook
      • marson
        • Feb 2011
        • 80
        long time ago......
        I have buy the small calipers zl/zr 17 today. I need a plug and play solution to fit them on my s2.
        Which rotors an adapter i need ? Who can help
        • terrybullwon
          • Mar 2006
          • 8782
          Chef
          • marson
            • Feb 2011
            • 80
            I dont understand....
            The brakets don“t fit on the small Cayenne calipers.
            And which rotors i need ?
