another problem
  • rocketdog
    • Feb 2009
    • 58
    another problem
    every morning when i start my s2 i get (!), pas fluid and brake fluid levels are correct. any ideas??
  • Knight Rider S4
    • 3541
    brake bomb is my first guess, I have this with my avant and positive it is the bomb..check the bottle top of the PS fluid tank too..loose connection can cause this to
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • rocketdog
      • Feb 2009
      • 58
      any ideas on how much thats gonna cost?
      • Fat Audi 80
        • 10547
        Mine has done that for 5 years, as long as it passes the "bomb test" (switch off engine after a run, pump brake pedal counting the pumps untill the pedal goes hard). You should get about 50. Anything less than 30 or so is a concern....
        Cheers,
        Steve.
        The Perfectionist
        • irishs2
          • Apr 2009
          • 2455
          Does the light go out when you tap the brake pedal once?
          Eric
          95 S2 Avant under rebuild.
          • rocketdog
            • Feb 2009
            • 58
            the light stays on for about 10 seconds after start up, i did bomb test and stopped counting after 40 but it did force pas fluid out of the top of the tank? i topped the level up because of the warning light but think i probably put too much in
            • europeanme
              • Oct 2005
              • 3817
              might sound like a daft question....have you checked your brake pipes??....
              I had this last winter and it turned out to be a previously secured rear brake line joint had started weeping...one quick nip and "roberts your mothers brother"...
              • rocketdog
                • Feb 2009
                • 58
                i haven't checked brake pipes because it passed MOT 2 weeks ago but if it ever stops raining long enough to get underneath it i will check the connections, cheers for the ideas guys
                  First thing to check is the PAS reservoir top cap, there's a low level switch in the cap that gets dirty and triggers the alarm - my money is on this as 40 pumps on the bomb sounds fine. It will increase the level of the fluid in the tank, don't worry about it, just make sure it's topped up with the bomb fully charged.
                  • popdemonic
                    • Dec 2007
                    • 1304
                    • Country: Thailand
                    Doing the same thing on my S6....
                    3 years ago..
                    1.Replaced new bomb(but the bomb had been on the shelf for many years) got 25 times at that time when first installed.big chance that the nitrogen will discharge itself as the time goes by.
                    2.Replaced brand new Brake Servo.damn Expensive.
                    3.good known of used Pump.
                    Now Bomb testing,it could count only 17 times on the stroke.My car is auto tranny so I need
                    to keep the foot on brake pedal all the times when I was in traffic.The (!) light on and
                    the pedal pulsating all the times.That's really annoying me.i'm going to get new bomb from Paul
                    ASAP.
                    one of a few I5 from Asia.
