Abs Light Wan't Go Out After Hard Braking
  • david
    • Oct 2008
    • 1268
    ABS light stay's on and wan't go out after braking hard.does anyone have any idea why?.Can a worn pads course it to stay on all the time?
    [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
    RS2 VOLCANO BLACK] soon to be broken to bits
  • A80Avant
    • 10873
    • Country: Greece
    do you have a diagnostic? if so you can connect to the ABS ecu and check if any of the sensors are worn.If not then it could be the brake bomb
    • 220bhp
      • 2578
      • Home: United Kingdom
      I had this problem,it was a rear caliper that that kept sticking had to replace it in the end, problem solved after that.
      • david
        • Oct 2008
        • 1268
        abs
        no, i don't have one.but i'll check the brake bomb
        • david
          • Oct 2008
          • 1268
          abs
          i'm due a brake change all round soon,so maybe i might get that done and see if that solve's the problem
          • bsavictor
            • 55
            • Home: United Kingdom Current: Scotland
            Have had the problem in the past, pump pressure a little low, tired pump, replaced, then perfect
