Hi - has anyone experienced the following and if so - how was the problem solved? Thanx in advance
When braking (normal driving) and when the speed gets to 70km/h there is a shudder that can be felt on the steering.
So I'm doing say 120km/h and start braking - everything is fine, until I slow down to 70km/h - and the shudder is apparent.
Oh this is on an RS2.
New front disc's and pads were replaced about +- 10k kms - OEM parts standard size. Discs and pads still look fine.
Your help is appreciated - what should I be looking for/check?
Going to be trial and error really, suggest you try some new pads first (cheapest) and then you're looking at discs and a caliper rebuild. Discs and pads didn't sort the problem on the S4 BW. Oh, and check that the wheel bolts are tight too
