steering wobble on braking
  • jay walker
    • Feb 2009
    • 113
    when i brake in the se the steering wheel wobbles, it doesnt feel like a warped discs and the front wheels arent loose, if i turn the ABS off it is better but still there.
    question is is what do you think it is, im thinking replace the master cylinder and a bleed. anyone got any other ideas what causing it? it not loosing any brake fluid and the fluid is at the correct level. cheers for help
    Jay
  • Sonic
    • Jul 2006
    • 5514
    what brakes are you running?
    S2Forum.com Administrator
    • madpugger
      • Sep 2007
      • 1901
      Warped discs. I think the turning off the ABS off is probably making it better in your head!
      Is it worse when light braking?
      Le Mans 2012
      Nurburgring 700
      1995 S2 Avant
      • mcandmar
        • Apr 2004
        • 5118
        Sounds like you need new disks. I find when they get old they corrode on the inside edge of the disk near the hub. Feels like a warped disk but its just the pads hitting the build up of rust.
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
