rs2 calipers, from what porsche?
  • lind4hl
    • Jul 2008
    • 2465
    Edited.
    how thick is the oem brake pad'??
    I believe they were off the 968.
    • lind4hl
      • Jul 2008
      • 2465
      hmm according to carbotech 968 has 2 different front calipers sport and base.
      • curlyks2
        • 1069
        My catalogue suggests that no Porsche parts are a direct perfect fit: RS2 pads, while being the same shape and very very nearly same size (width and height), are 2mm less thick.
        This post lists the most similar Porsche models which had the closest match.
        Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
        • lind4hl
          • Jul 2008
          • 2465
          hmm, i will have to send an mail to carbotech i think..
            Big reds are same as the 968 CS I believe
            • alg
              • Apr 2004
              • 1160
              Big reds were the same as the turbo (964 at that time as 993 turbo had not arrived at RS2 launch ) & the uprated 968 M30 calipers. Often easier to look/ask for M30 when dealing with porsche independents. They are thicker but usually Ok if not fitting with brand new discs. Best IMHO are DS2500. If yousearch then there are several threads dealing with part numbers you need & suppliers
              Alastair
              RS2
              • lind4hl
                • Jul 2008
                • 2465
                i have contacted carbotech about it, IMO carbotech is better than ds2500.. cheers for the heads up
                • lind4hl
                  • Jul 2008
                  • 2465
                  edit 1 post, new question
                  • curlyks2
                    • 1069
                    My catalogue shows the following dimensions (all in mm):
                    RS2 Front Pads
                    Width: 131
                    Height: 70
                    Depth: 16
                    Porsche 968 M030 (etc) Front Pads
                    Width: 131
                    Height: 71
                    Depth: 18
                    • lind4hl
                      • Jul 2008
                      • 2465
                      the pads i want to order are 16,5mm should work huh?
                      • alg
                        • Apr 2004
                        • 1160
                        Yes
                        Alastair
                        RS2
