Just wondering if the a8 discs can be re drilled to 4x108?
Just if so it would make installing a set of bigger brakes a bit cheaper but dont know if the a8 discs have enough meat to re drill, I have seen some five stud discs with 10 holes?
Hi all,
This thread is for my 1991 CQ which I purchased last summer in Burlington, VT.
In a slight deviation from previous project threads, I'd like to keep all discussion separate from the actual project thread. Please post all comments/questions/etc. over here...
Acidburn was talking of someone using ford discs insted as they are 4x108 already. I have never bothered asking more about this as I have no plans for a brake upgrade just now. But maybe he could pipe up now and tell us who done it or how it was done?
andy
I know we scots have a reputation of being tight... but are you not taking the money saving a little too far???
At the end of the day BRAKES can save your life (or not) are you sure you wanna cut corners for A FEW QUID????
What if you sell the car to someone who has a young family..... would you take the resposability for them in a crash????
If you try to understand, what holds brake disk in place - you won't be so scared. It's the wheel, not the brake disk holes. Of course if you have spare money - you can spend it for S2/urq struts. But remember there's thin line between true safety, and paranoia. I prefer to take risks if I can fully understand them (sometimes even CAD analysis helps me there).
Sau
My thoughts were based around the fact if the manufacturer don't do them with that DP is there not a reason for it!! by drilling holes in the hub are you not infact weakening the overall structure of the disk???
I am not an engineer or a mechanic so I maybe talking total b**locks but lets just say you did this "conversion" and then they failed - on the off chance -and you totalled the car...
Could you resonably argue with the IC that "your" conversion didn't cause it....
Le S2 Audi-dont be sorry, I appreciate the input, I was thinking the disc is clamped by the wheel rather than stopped from rotating by the bolts, also I am talking about drilling the disc rather than the hub.
I wont be putting bigger brakes on tommorrow, just costing up options.
One of my mates has been working on turning a 4 stud hub into 5 stud but don't know how far he got, he was planning on fitting it to a cheap 20v cq etc and testing it out.
