rs2 drilled discs and pads?
  • adamw
    • Dec 2005
    • 348
    • Country: Shetland Islands
    after searching all the related threads i still dont have a difinative answer.....
    what are the audi or porsche (who ever is cheaper) part numbers for drilled discs and pads front and rear??
    304mm fronts:
    290mm rears:
    cheeRS adam
    RS2+
  • A80Avant
    • 10873
    • Country: Greece
    instead of getting those from the dealers, i suggest you get them from ebay germany. They are dead cheap and are original parts as well. Ultimot.de also sells them in very good prices. I got my 322x32 front discs from them for 500euros the pair.They cost about 500euro each from audi
    • Lloyd
      • Apr 2006
      • 1559
      The cheapest place for front 'BIG' discs 965-351-045-00 and 965-351-046-00 is from
      Simon or Brian at Jasmine 01282 697 171. These discs are OEM Porsche discs (911 Turbo) and not 'aftermarket' alternatives. I paid £128.29 each + VAT. These are the same as genuine OEM RS2 big discs. Zinc coating and same drill pattern to match RS2 drilled OEM rears.
      You could also try Jon at Design911 020 8500 8811.
      For the rears, sadly the ONLY place to get the OEM RS2 drilled disc is from Audi.
      I bought a pair yesterday for £416 from Audi in Hatfield, including 25% discount!
      The OEM discs have the double row of holes (cosmetic only I know ) and spray finished zinc coating on the highly visible bell and outer edge of the disc.
      If you don't want the cosmetic holes, you can get the non drilled 928 option with the zinc from Porsche. Take care to order the right version. If you want the non drilled 928 version its 951-352-041-01. As far as I know the RS2 rears are the same dimensions as rear discs on all 928's 1983 -1995 incl. GTS and 944 1985 -1988.
      NB:
      I've not ordered or tested fitment of these rear disc part numbers myself!
      However, I believe they're correct.
      I also know for a fact that 951-352-041-91 DOES NOT FIT as stated on an old Porsche/RS2 spreadsheet. I know cos I bought some.
      Personally, I'm not in favour of some of the aftermarket options for the rear discs as they rust up quick, look tatty and perhaps most important the inner surface for the handbrake is not as nicely prepped for efficient handbrake operation.
      You could always paint 'em to stop rust but you're still left with potential handbrake issues and non matching drill pattern with ya front discs....
      Most recently, I've read about Zimmerman coating their newer discs with "Z-Coat" a clear coat to inhibit rust.
      HTH
      RS2+ (now sold...)
      • adamw
        • Dec 2005
        • 348
        Lloyd: you say the front discs are for the big brakes... ie' 322mm?
        does anybody know the part numbers for the drilled discs for the 304mm 'little reds'?
        i know people will say instead of getting drilled go for the 'big reds' or better... thats the plan BUT not at the moment.
        i would like to go 6 or even 8pots in the future
        cheeRS adam
        RS2+
        • veneto rs2
          • Jun 2006
          • 1022
          • Country: Veneto
          You can have the "small" front drilled discs from Zimmerman.
          I had them on before upgrading to big reds and IMHO they were just very good.
          Stefano
          http://www.audisportclub.com/
            Both front and rear are available from Zimmerman at GSF or design911.co.uk
            There's a massive thread on the forum with part numbers from GT500
            • Lloyd
              • Apr 2006
              • 1559
              928S4-M030 304mmx32mmx77mm Rotors
              965-351-041-01 and 965-351-042-01
              "Cross-drilled" - bolt directly onto RS.
              1994-96 RS2 Original 304mmx32mmx77mm Rotors
              928-351-043-60 or 928-351-044-60
              Stock rotors, non cross drilled.
              Again, buy from Jasmine for best prices.
              Please double check all the dimensions before ordering!
              RS2+ (now sold...)
              • adamw
                • Dec 2005
                • 348
                thank you very much Lloyd!
                your a true gentleman!
                cheeRS adam
                RS2+
